Hi
I am using a Asrock 939 Dual Sata2 with 1GB corsair value pc3200 ram. When the bios is at default settings the ram is at 166mhz when it should be 200mhz, if I increase the HTT the ram will stay at 166mhz even if I change the memory divider. It doesn't matter what I do the memory speed won't change.
When I first built the system it worked fine but it started doing this about a month ago, i've tried updating the bios but it doesn't make a difference.
Anyone got any ideas on how to fix this.
Thanks
Thanks
