Memory speed/timings question
18 May 2010
Hi,
I recently noticed my memory was running at 1333 and realised my memory was capable of 1600 so I set about sorting it out, forgive me for being vague but I'm not too good at this I've just started to mess with it
It was running at 1333, 1.5V and 8T/8T/8T/24
It wont boot at 1600, 1.6V and 8T/8T/8T/24
It will boot at 1600, 1.6V and 9T/9T/9T/24
Is it better to leave it as it is or revert back to the 1333 settings IE CAS 8 is better or is CAS 9 ok?
Is the voltage too high or should I try dropping it?
CPU if it matters is a Phenom 965 at 3.6
Thanks
Here's a screen shot of CPU-Z
Thanks, just tried it and get blue screen in windows at 1.5
Just set the voltage to auto but not sure what its applying as its not clear but the PC doesn't blue screen and CPU-Z states 1600 at 9T
Ok thanks, in the BIOS I change it to 1.6 but AMD Overdrive states its still 1.5 and Prime95 fails straight away, if I revert the memory back to old settings 1333 at 1.5 Prime95 runs ok :confused:
What I don't get is if its 1600 memory how come it wont run at 1600
I got it to run now, it didn't apply 1.6 the first for some reason, applied it again and double checked and its fine it now runs prime at 1600 cas9 and 1.6
Moved onto overclocking my cpu now trying to get to run at 3.8 but getting issues after half an hour
You need to run memory tests, as if you're bumping up voltage to get the memory to work it may not be fully stable yet, even if it seems so.
To some extent, but dedicated memory tests are far better.
I think the Phenom is only rated to run at 1333MHz memory, so 1600MHz is an overclock.
You won't do any harm, you just need to make sure it's stable.
Here's a good one:
http://www.memtest.org/
As an example, I increased the speed of my RAM and it was passing stress tests, but when I ran memtest86+, half way through it gave a memory error. An increase in voltage and it passed fine.
