Memory Speed XMP.
Caporegime
8 Nov 2008
Hey,
My memory is 2400mhz but automatically downclocks to 2133, so I've increased it to 2400 with the XMP profile. However, I'm not sure it's entirely 100% happy about that, though, for the most part, it seems to be ok.
Is there anything I should do like increasing voltage or run a test of some kind? Memory is one of the things I'm most inexperienced on so any help would be appreciated.
Ta. :)
Can you post the full specs of your machine as this varies a lot.
(Currently, Windows 7 64bit HP)
6600K (4.2ghz)
Gigabyte Z170X Gaming 3 motherboard
16gb Corsair Vengeance Low Profile DDR4 (2400mhz)
Be Quiet! 650w
Is that enough or do you want absolutely everything? I've included what I imagine will be relevant. :)
Sig updated now anyway, so hopefully, that'll be sufficient.
Yep, it really doesn't like it. The PC wouldn't even restart so I had to power it down then start up again, enter the bios and disable the XMP profile.
Limitation of the motherboard?
