Hi stulid, ive no idea how to post a picture of cpu-z onto this forum, only thing I could do was get a txt report of system from cpu-z. Hope this shows ok. I used both pairs of ram separately and one set shows 2400mhz in bios, other set shows 1333mhz. Only boots with XMP OFF with all 4 sticks inserted. As you can see all four dims show the same part number.
CPU-Z TXT Report
Binaries
CPU-Z version 1.72.0.x64
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
-- Core 2
-- Thread 0 4
-- Thread 1 5
-- Core 3
-- Thread 0 6
-- Thread 1 7
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.904 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 8 (max 16)
Name Intel Core i7 4790K
Codename Haswell
Specification Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 88.0 Watts
Tjmax 100.0 °C
Core Speed 799.2 MHz
Multiplier x Bus Speed 8.0 x 99.9 MHz
Stock frequency 4000 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 40x
Max turbo ratio 44x
Max efficiency ratio 8x
O/C bins unlimited
Ratio 1 core 44x
Ratio 2 cores 44x
Ratio 3 cores 44x
Ratio 4 cores 44x
TSC 3997.6 MHz
APERF 4210.8 MHz
MPERF 3975.9 MHz
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 102 mV
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020201h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306C3 0x00100800 0x7FFAFBBF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B5FF 0x00000000 0x00C10000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00042120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00002FBB 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000021 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x3937342D 0x43204B30 0x40205550
0x80000004 0x302E3420 0x7A484730 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003027 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000001
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00080838 0xF3012800
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040008
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x2C2C2C2C
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88470800
MSR 0x000001FC 0x00000000 0x0004005D
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00101414 0x00001FFF
MSR 0x00000610 0x0042FFF8 0x001AFFF8
MSR 0x00000611 0x00000000 0x052FBEF4
MSR 0x00000639 0x00000000 0x0130FE85
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000619 0x00000000 0x02943003
MSR 0x00000614 0x00000000 0x000002C0
MSR 0x0000019C 0x00000000 0x884B0000
MSR 0x000001A2 0x00000000 0x00641400
MSR 0x00000198 0x000018C1 0x00000800
MSR 0x00000199 0x00000000 0x00000800
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
Type 01020201h
CPUID
0x00000001 0x000306C3 0x01100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x000001B1 0x00000000 0x88460800
MSR 0x00000611 0x00000000 0x052FD94E
MSR 0x00000639 0x00000000 0x01310E54
MSR 0x00000619 0x00000000 0x029437CF
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020201h
CPUID
0x00000001 0x000306C3 0x02100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000002
MSR 0x000001B1 0x00000000 0x88480800
MSR 0x00000611 0x00000000 0x052FF3E4
MSR 0x00000639 0x00000000 0x01311ED4
MSR 0x00000619 0x00000000 0x02943F51
MSR 0x0000019C 0x00000000 0x88490000
MSR 0x00000198 0x00001889 0x00000800
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
Type 01020201h
CPUID
0x00000001 0x000306C3 0x03100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000003
MSR 0x00000611 0x00000000 0x05301077
MSR 0x00000639 0x00000000 0x013130F1
MSR 0x00000619 0x00000000 0x0294471D
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01020201h
CPUID
0x00000001 0x000306C3 0x04100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x05302CE9
MSR 0x00000639 0x00000000 0x01314325
MSR 0x00000619 0x00000000 0x02944EA1
MSR 0x0000019C 0x00000000 0x884A0000
MSR 0x00000198 0x000018AB 0x00000800
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
Type 01020201h
CPUID
0x00000001 0x000306C3 0x05100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000005
MSR 0x00000611 0x00000000 0x05304937
MSR 0x00000639 0x00000000 0x0131550E
MSR 0x00000619 0x00000000 0x0294566C
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01020201h
CPUID
0x00000001 0x000306C3 0x06100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
MSR 0x00000611 0x00000000 0x053064B1
MSR 0x00000639 0x00000000 0x0131667D
MSR 0x00000619 0x00000000 0x02945DEE
MSR 0x0000019C 0x00000000 0x884C0000
MSR 0x00000198 0x000018AF 0x00000800
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
Type 01020201h
CPUID
0x00000001 0x000306C3 0x07100800 0x7FFAFBBF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000007
MSR 0x00000611 0x00000000 0x0530820B
MSR 0x00000639 0x00000000 0x0131792A
MSR 0x00000619 0x00000000 0x029465B7
Chipset
Northbridge Intel Haswell rev. 06
Southbridge Intel Z97 rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x8
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 32 GBytes
Channels Dual
Memory Frequency 666.1 MHz (1:5)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Row Refresh Cycle Time (tRFC) 174
Command Rate (CR) 2T
Uncore Frequency 3996.2 MHz
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 19456
MCHBAR registers
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Kingston (7F980000000000000000)
Size 8192 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number KHX2400C11D3/8GX
Serial number 751C0DFC
Manufacturing date Week 24/Year 14
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.3
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-17-23 @ 457 MHz
JEDEC #2 7.0-7-7-20-27 @ 533 MHz
JEDEC #3 8.0-8-8-22-30 @ 609 MHz
JEDEC #4 9.0-9-9-24-33 @ 666 MHz
XMP profile XMP-2400
Specification PC3-19200
Voltage level 1.650 Volts
Min Cycle time 0.833 ns (1200 MHz)
Max CL 11.0
Min tRP 10.83 ns
Min tRCD 10.83 ns
Min tWR 15.00 ns
Min tRAS 26.67 ns
Min tRC 45.00 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 5.83 ns
Command Rate 1T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 6.0-8-8-18-30-1T @ 654 MHz (1.650 Volts)
XMP #2 7.0-9-9-21-35-1T @ 763 MHz (1.650 Volts)
XMP #3 8.0-10-10-24-40-1T @ 872 MHz (1.650 Volts)
XMP #4 9.0-11-11-27-45-1T @ 981 MHz (1.650 Volts)
XMP #5 10.0-12-12-30-50-1T @ 1090 MHz (1.650 Volts)
XMP #6 11.0-14-14-33-54-1T @ 1200 MHz (1.650 Volts)
XMP #7 12.0-14-14-33-54-1T @ 1200 MHz (1.650 Volts)
XMP #8 13.0-14-14-33-54-1T @ 1200 MHz (1.650 Volts)
XMP #9 14.0-14-14-33-54-1T @ 1200 MHz (1.650 Volts)
XMP #10 15.0-14-14-33-54-1T @ 1200 MHz (1.650 Volts)
XMP profile XMP-2132
Specification PC3-17100
Voltage level 1.600 Volts
Min Cycle time 0.938 ns (1066 MHz)
Max CL 11.0
Min tRP 12.19 ns
Min tRCD 12.19 ns
Min tWR 15.00 ns
Min tRAS 28.13 ns
Min tRC 45.00 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 6.56 ns
Command Rate 1T
XMP #1 6.0-8-8-17-27-1T @ 581 MHz (1.600 Volts)
XMP #2 7.0-9-9-20-31-1T @ 678 MHz (1.600 Volts)
XMP #3 8.0-10-10-22-35-1T @ 775 MHz (1.600 Volts)
XMP #4 9.0-11-11-25-40-1T @ 872 MHz (1.600 Volts)
XMP #5 10.0-12-12-28-44-1T @ 969 MHz (1.600 Volts)
XMP #6 11.0-13-13-30-48-1T @ 1066 MHz (1.600 Volts)
XMP #7 12.0-13-13-30-48-1T @ 1066 MHz (1.600 Volts)
XMP #8 13.0-13-13-30-48-1T @ 1066 MHz (1.600 Volts)
XMP #9 14.0-13-13-30-48-1T @ 1066 MHz (1.600 Volts)
XMP #10 15.0-13-13-30-48-1T @ 1066 MHz (1.600 Volts)
DIMM # 2
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Size 8192 MBytes
Max bandwidth PC3-12800 (800 MHz)
Serial number 6E1A9A1D
Manufacturing date Week 50/Year 14
Number of banks 8
EPP no
XMP yes
XMP revision 1.3
AMP no
JEDEC #1 6.0-6-6-16-22 @ 457 MHz
JEDEC #2 7.0-7-7-19-26 @ 533 MHz
JEDEC #4 9.0-9-9-24-33 @ 685 MHz
JEDEC #5 10.0-10-10-27-37 @ 761 MHz
JEDEC #6 11.0-11-11-28-39 @ 800 MHz
Specification PC3-19200K
Max CL 11.0
Min tRP 11.67 ns
Min tRCD 10.83 ns
Min tWR 15.00 ns
Min tRAS 26.67 ns
Min tRC 45.00 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 5.83 ns
Command Rate 1T
XMP #3 8.0-10-11-24-40-1T @ 872 MHz (1.650 Volts)
XMP #4 9.0-11-12-27-45-1T @ 981 MHz (1.650 Volts)
XMP #5 10.0-12-13-30-50-1T @ 1090 MHz (1.650 Volts)
Max CL 11.0
Min tRP 12.19 ns
Min tRCD 12.19 ns
Min tWR 15.00 ns
Min tRAS 28.13 ns
Min tRC 45.00 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 6.56 ns
Command Rate 1T
DIMM # 3
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 8192 MBytes
Serial number 731C10FC
Number of banks 8
EPP no
XMP yes
XMP revision 1.3
AMP no
Max CL 11.0
Min tRP 10.83 ns
Min tRCD 10.83 ns
Min tWR 15.00 ns
Min tRAS 26.67 ns
Min tRC 45.00 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 5.83 ns
Command Rate 1T
Max CL 11.0
Min tRP 12.19 ns
Min tRCD 12.19 ns
Min tWR 15.00 ns
Min tRAS 28.13 ns
Min tRC 45.00 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 6.56 ns
Command Rate 1T
DIMM # 4
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 8192 MBytes
Serial number 681A9C1D
Number of banks 8
EPP no
XMP yes
XMP revision 1.3
AMP no
Max CL 11.0
Min tRP 11.67 ns
Min tRCD 10.83 ns
Min tWR 15.00 ns
Min tRAS 26.67 ns
Min tRC 45.00 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 5.83 ns
Command Rate 1T
Max CL 11.0
Min tRP 12.19 ns
Min tRCD 12.19 ns
Min tWR 15.00 ns
Min tRAS 28.13 ns
Min tRC 45.00 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 6.56 ns
Command Rate 1T
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 11 0B 02 04 21 00 09 03 11 01 08 0C 00 3C 00
10 69 78 69 30 69 11 20 89 20 08 3C 3C 00 F0 83 81
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 21 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 01 98 07 14 24 75 1C 0D FC D8 69
80 4B 48 58 32 34 30 30 43 31 31 44 33 2F 38 47 58
90 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0C 4A 03 13 01 0C 01 10 11 2D 0A 6E FC 0F 64 82
C0 82 B4 21 40 1C 5E 00 30 0C 5A 46 01 68 5A 00 00
D0 14 00 27 00 00 00 00 00 00 00 00 00 2C 0F A5 FC
E0 0F 96 C3 C3 F0 21 C2 D0 7D 00 40 10 78 69 01 E0
F0 78 00 00 1E 00 26 00 00 00 00 00 00 00 00 00 5A
DIMM # 2
SPD registers
00 92 11 0B 02 04 21 00 09 03 11 01 08 0A 00 FC 00
10 69 78 69 30 69 11 18 81 20 08 3C 3C 00 F0 83 01
70 00 00 00 00 00 01 98 07 14 50 6E 1A 9A 1D 25 7D
B0 0C 4A 03 13 01 0C 01 10 11 2D 0A 6E FC 0F 64 8C
DIMM # 3
SPD registers
70 00 00 00 00 00 01 98 07 14 24 73 1C 10 FC D8 69
DIMM # 4
SPD registers
70 00 00 00 00 00 01 98 07 14 50 68 1A 9C 1D 25 7D
Monitoring
Mainboard Model MAXIMUS VII HERO (0x0000047A - 0xA909AFF8)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6791
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC8
LPCIO Revision ID 0x3
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF 0A 26 00 00 FF FF
20 C8 03 FF 00 00 00 00 00 10 FF 40 00 00 02 00 03
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 00 00 0A 00 FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Register space class = 0x8, base address = 0x0A00
Hardware Monitors
Hardware monitor Nuvoton NCT6791D
Voltage 0 5.16 Volts [0x81] (+5V)
Voltage 1 3.38 Volts [0xD3] (+3.3V)
Voltage 2 12.00 Volts [0x7D] (+12V)
Voltage 3 0.94 Volts [0x76] (VIN3)
Voltage 4 0.77 Volts [0x30] (VIN4)
Voltage 5 1.86 Volts [0x74] (VCORE)
Temperature 0 25°C (77°F) [0x19] (Mainboard)
Temperature 1 28°C (82°F) [0x1C] (CPU)
Fan 3 1192 RPM [0x4A8] (CPU)
00 74 81 D3 D3 7D FA 30 D6 CD 7F 00 76 30 30 30 00
10 19 1A 44 80 1D 44 00 29 00 1B 1B 1B 1B 1B 44 00
20 19 02 99 99 99 99 99 00 00 00 00 00 00 00 FF 1F
30 12 1F FF 1F FF 1F FF 1F 23 1F 00 00 09 13 00 00
40 00 00 00 00 04 AA 00 00 00 00 00 00 99 99 99 99
50 99 FF 1D 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 1B 00 FE 00 FF FF FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor ACPI
Temperature 0 28°C (82°F) [0xBC2] (TZ00)
Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.86 Volts [0x358] (VIN0)
Temperature 0 35°C (95°F) [0x23] (TMPIN0)
Fan 0 1052 RPM [0x41C] (FANIN0)
Fan PWM 0 22 pc [0x16] (FANPWMIN0)
Voltage 0 0.86 Volts [0x35E] (VIN0)
Temperature 0 29°C (84°F) [0x1D] (TMPIN0)
Fan 0 1051 RPM [0x41B] (FANIN0)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0C00
Revision ID 0x06
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Vendor Dependant
Caps offset 0xE0
PCI registers
00 86 80 00 0C 06 00 90 20 06 00 00 06 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 34 85
30 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
40 01 90 D1 FE 00 00 00 00 01 00 D1 FE 00 00 00 00
50 03 00 00 00 0D 00 00 00 04 00 00 00 01 00 00 BF
60 05 00 00 F8 00 00 00 00 01 80 D1 FE 00 00 00 00
70 00 00 00 FF 07 00 00 00 00 0C 00 FF 7F 00 00 00
80 10 11 11 00 00 00 11 00 1A 00 00 00 00 00 00 00
90 01 00 00 FF 07 00 00 00 01 00 F0 3E 08 00 00 00
A0 01 00 00 00 08 00 00 00 01 00 00 3F 08 00 00 00
B0 01 00 00 C0 01 00 00 C0 01 00 00 BF 01 00 00 C0
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 09 00 0C 01 6D A0 00 42 D0 00 44 36 00 00 00 00
F0 00 00 00 00 C8 0F 03 00 00 00 00 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x0C01
Revision ID 0x06
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps class Subsystem Vendor
Caps offset 0x88
SubVendor ID 0x1043
SubSystem ID 0x8534
PCI capability
Caps class Power Management
Caps offset 0x80
Caps version 1.2
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x90
PCI capability
Caps class PCI Express
Caps offset 0xA0
Device type Root Port of PCI-E Root Complex
Port 2
Version 2.0
Physical slot #0
Presence detect yes
Link width 8x (max 8x)
Extended capabilities
Caps class Virtual Channel
Caps offset 0x100
Caps class Root Complex Link Declaration
Caps offset 0x140
Link Entries # 1
Port Number 2
Caps class 0x19
Caps offset 0xD94
PCI registers
00 86 80 01 0C 07 00 10 00 06 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 01 01 00 E0 E0 00 20
20 00 F6 00 F7 01 E0 F1 F1 00 00 00 00 00 00 00 00
30 00 00 00 00 88 00 00 00 00 00 00 00 10 01 18 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A
80 01 90 03 C8 08 00 00 00 0D 80 00 00 43 10 34 85
90 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 10 00 42 01 00 80 00 00 00 00 00 00 83 AC 61 02
B0 40 00 81 D0 80 25 0C 00 00 00 40 00 00 00 00 00
C0 00 00 00 00 80 0B 08 00 00 64 00 00 0E 00 00 00
D0 43 00 1E 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 60 01 D0 4E 01 01 42 00 00 00 00 00 00 10 00
100 02 00 01 14 00 00 00 00 00 00 00 00 00 00 00 00
110 01 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x0C05
Revision ID 0x06
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x88
SubVendor ID 0x1043
SubSystem ID 0x8534
PCI capability
Caps offset 0x80
Caps version 1.2
PCI capability
Caps offset 0x90
PCI capability
Caps offset 0xA0
Port 3
Version 2.0
Physical slot #0
Presence detect yes
Caps offset 0x100
Caps offset 0x140
Link Entries # 1
Port Number 3
Caps class 0x19
Caps offset 0xD94
PCI registers
00 86 80 05 0C 07 00 10 00 06 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 02 02 00 D0 D0 00 20
20 00 F4 00 F5 01 C0 F1 D1 00 00 00 00 00 00 00 00
30 00 00 00 00 88 00 00 00 00 00 00 00 10 01 04 00
A0 10 00 42 01 00 80 00 00 00 00 00 00 83 AC 61 03
B0 40 00 81 D0 80 25 14 00 00 00 40 00 00 00 00 00
F0 00 60 01 00 4E 01 01 42 00 00 00 00 00 00 10 00
Description USB Controller
Location bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8CB1
Revision ID 0x00
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF5120000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x70
Caps version 1.1
PCI capability
Caps offset 0x80
PCI registers
00 86 80 B1 8C 06 04 90 02 00 30 03 0C 00 00 00 00
10 04 00 12 F5 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 70 00 00 00 00 00 00 00 00 01 00 00
40 FD 01 36 80 89 C6 0F 80 00 00 00 00 00 00 00 00
50 9F 6E 88 07 00 00 00 00 00 00 00 00 00 00 00 00
60 30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 01 80 C2 C1 08 00 00 00 00 00 00 00 00 00 00 00
80 05 00 B7 00 0C F0 EF FE 00 00 00 00 B8 49 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0F 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 01 0C 30 C0 03 0C 30 00 03 0C 30 00 00 00 00 00
D0 FF 3F 00 00 FF 3F 00 00 3F 00 00 00 3F 00 00 00
E0 A0 00 00 00 00 00 00 00 00 00 00 00 D8 D8 D8 08
F0 00 00 00 00 00 00 00 00 B1 0F 00 08 00 00 00 00
Description Communication Device
Location bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8CBA
Revision ID 0x00
PI 0x00
SubClass 0x80
BaseClass 0x07
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF513A000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x8C
PCI registers
00 86 80 BA 8C 06 04 10 00 00 00 80 07 00 00 80 00
10 04 A0 13 F5 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
40 55 02 00 1E 10 00 01 80 06 23 00 66 F0 7F 00 10
50 01 8C 03 C8 08 00 00 00 00 00 00 00 00 00 00 00
60 00 02 00 00 00 40 00 00 00 00 00 00 00 00 00 40
70 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 05 00 81 00
90 0C F0 EF FE 00 00 00 00 A2 49 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 C0
C0 55 C0 D8 D3 03 E0 97 32 55 9E 55 7B F3 56 51 50
D0 B0 55 37 89 8C BA 49 1B 61 E8 46 4E BE 5B B3 57
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Ethernet Controller
Location bus 0 (0x00), device 25 (0x19), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x15A1
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF5100000
Address 1 (memory) 0xF5138000
Subvendor ID 0x1043
Subsystem ID 0x85C4
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0xC8
Caps version 1.1
PCI capability
Caps offset 0xD0
PCI capability
Caps class 0x13
Caps offset 0xE0
PCI registers
00 86 80 A1 15 06 04 10 00 00 00 00 02 00 00 00 00
10 00 00 10 F5 00 80 13 F5 01 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 C4 85
30 00 00 00 00 C8 00 00 00 00 00 00 00 00 01 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 46 08 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 01 D0 22 C8 00 21 00 07
D0 05 E0 81 00 0C 10 E0 FE 00 00 00 00 B2 49 00 00
E0 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8CAD
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF5137000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x14
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 AD 8C 06 00 90 02 00 20 03 0C 00 00 00 00
10 00 70 13 F5 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 14 01 00 00
40 00 00 00 00 DB 05 95 33 00 00 00 00 00 00 00 00
50 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
60 20 20 FF 07 00 00 00 00 01 00 00 01 00 20 00 00
70 00 00 DF 3F 03 0C 30 00 4F 01 00 00 8C 40 00 00
80 00 00 80 00 11 88 0C 93 70 0D 00 24 01 04 02 00
90 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
D0 00 00 00 00 00 AA FF 00 00 00 1C 2A 27 00 00 00
E0 00 00 00 00 FF FF FF FF FF FF FF FF FC EB FD E5
F0 00 00 00 00 88 85 80 00 B1 0F 00 08 08 17 1A 20
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8CA0
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF5130000
Subvendor ID 0x1043
Subsystem ID 0x8602
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x60
PCI capability
Caps offset 0x70
Device type Root Complex Integrated Endpoint Device
Port 0
Version 1.0
Link width 0x (max 0x)
Caps offset 0x100
PCI registers
00 86 80 A0 8C 06 00 10 00 00 00 03 04 10 00 00 00
10 04 00 13 F5 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 02 86
30 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
40 03 00 00 17 00 00 00 00 00 00 00 00 00 80 00 00
50 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
C0 00 04 02 01 00 60 00 00 00 0C 85 82 10 00 33 02
D0 00 0C 85 02 10 00 33 02 00 00 00 00 00 00 00 00
100 02 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
120 04 00 00 82 00 00 00 00 00 00 00 00 00 00 00 00
130 05 00 01 00 00 01 00 0F 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8C90
Revision ID 0xD0
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x40
Port 1
Version 2.0
Physical slot Integrated device
Link width 0x (max 2x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1043
SubSystem ID 0x8534
PCI capability
Caps offset 0xA0
Caps version 1.2
PCI registers
00 86 80 90 8C 04 00 10 00 D0 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 03 03 00 F0 00 00 20
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 10 01 00 00
40 10 80 42 00 00 80 00 00 00 00 10 00 22 4C 31 01
50 00 00 01 18 60 00 04 00 00 00 40 00 00 00 00 00
60 00 00 00 00 17 08 08 00 00 04 00 00 00 00 00 00
70 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 0D A0 00 00 43 10 34 85 00 00 00 00 00 00 00 00
A0 01 00 03 C8 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 01 00 08 00 00 02 00 11 09 00 00 00 00
E0 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 50 00 00 00 80 F5 00 00 B1 0F 00 08 01 68 0A 41
100 00 00 00 00 00 00 00 00 00 00 00 00 11 00 06 00
110 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 28 (0x1C), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x8C96
Revision ID 0xD0
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x13
Int. Pin 0x04
PCI capability
Caps offset 0x40
Port 4
Version 2.0
Physical slot #0
Presence detect yes
Link width 1x (max 1x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1043
SubSystem ID 0x8534
PCI capability
Caps offset 0xA0
Caps version 1.2
PCI registers
00 86 80 96 8C 07 00 10 00 D0 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 04 04 00 C0 C0 00 00
20 30 F7 30 F7 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 13 04 00 00
40 10 80 42 01 00 80 00 00 00 00 10 00 12 3C 32 04
50 40 00 12 70 00 B2 1C 00 00 00 40 00 00 00 00 00
60 00 00 00 00 17 08 00 00 00 04 00 00 00 00 00 00
70 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 01 42 18 00 00 08 80 11 8B 00 00 00 00
E0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 50 00 00 00 40 00 00 0C B1 0F 00 08 00 28 00 04
Location bus 0 (0x00), device 28 (0x1C), function 6 (0x06)
Common header
Vendor ID 0x8086
Model ID 0x8C9C
Revision ID 0xD0
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0x12
Int. Pin 0x03
PCI capability
Caps offset 0x40
Port 7
Version 2.0
Physical slot #0
Presence detect yes
Link width 2x (max 2x)
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x90
SubVendor ID 0x1043
SubSystem ID 0x8534
PCI capability
Caps offset 0xA0
Caps version 1.2
PCI registers
00 86 80 9C 8C 06 00 10 00 D0 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 05 05 00 F0 00 00 00
20 20 F7 20 F7 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 12 03 00 00
40 10 80 42 01 00 80 00 00 00 00 10 00 22 3C 32 07
50 40 00 22 70 00 FD 34 00 00 00 40 00 00 00 00 00
E0 02 00 00 00 08 84 08 84 10 00 00 00 00 00 00 00
F0 50 00 00 00 40 00 00 0C B1 0F 00 08 00 28 00 07
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8CA6
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF5136000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x17
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps offset 0x58
PCI capability
Caps class 0x13
Caps offset 0x98
PCI registers
00 86 80 A6 8C 06 00 90 02 00 20 03 0C 00 00 00 00
10 00 60 13 F5 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
40 00 00 00 00 DB 05 51 31 00 00 00 00 00 00 00 00
70 00 00 DF 3F 01 0C 30 C0 4F 01 00 00 8C 40 00 00
D0 00 00 00 00 00 AA FF 00 00 00 FF FF 27 00 00 00
E0 00 00 00 00 FF FF FF FF FF FF FF FF 2C 85 5C 77
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x8CC4
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0xE0
PCI registers
00 86 80 C4 8C 07 00 10 02 00 00 01 06 00 00 80 00
40 01 18 00 00 80 00 00 00 01 1C 00 00 10 00 00 00
50 F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 8B 8A 8F 83 90 00 00 00 84 85 8E 86 F8 F0 00 00
70 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0
80 10 00 0F 3C 91 02 3C 00 01 0A 7C 00 69 00 04 00
90 00 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00
A0 10 06 A0 18 09 38 06 00 00 46 00 00 00 00 01 00
B0 00 00 00 00 00 00 00 00 20 01 00 20 00 00 00 00
D0 33 22 11 00 67 45 00 00 CF FF 00 00 0A 00 00 00
E0 09 00 0C 10 00 00 00 00 01 E8 00 90 00 00 00 00
F0 01 C0 D1 FE 00 00 00 00 B1 0F 00 08 00 00 00 00
Description Serial ATA Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x8C82
Revision ID 0x00
PI 0x01
SubClass 0x06
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000F090
Address 1 (port) 0x0000F080
Address 2 (port) 0x0000F070
Address 3 (port) 0x0000F060
Address 4 (port) 0x0000F020
Address 5 (memory) 0xF5135000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0x80
PCI capability
Caps offset 0x70
Caps version 1.2
PCI capability
Caps class 0x12
Caps offset 0xA8
PCI registers
00 86 80 82 8C 07 00 B0 02 00 01 06 01 00 00 00 00
10 91 F0 00 00 81 F0 00 00 71 F0 00 00 61 F0 00 00
20 21 F0 00 00 00 50 13 F5 00 00 00 00 43 10 34 85
30 00 00 00 00 80 00 00 00 00 00 00 00 11 02 00 00
40 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
70 01 A8 03 40 08 00 00 00 00 00 00 00 00 00 00 00
80 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 60 38 07 87 83 01 00 38 20 02 5C 20 20 04 00 80
A0 A8 00 00 00 00 00 00 00 12 00 10 00 48 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x8CA2
Revision ID 0x00
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF5134000
Address 4 (port) 0x0000F000
Subvendor ID 0x1043
Subsystem ID 0x8534
Int. Line 0x0F
Int. Pin 0x03
PCI registers
00 86 80 A2 8C 03 00 80 02 00 00 05 0C 00 00 00 00
10 04 40 13 F5 00 00 00 00 00 00 00 00 00 00 00 00
20 01 F0 00 00 00 00 00 00 00 00 00 00 43 10 34 85
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 03 00 00
40 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
80 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x17C2
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF6000000
Address 1 (memory) 0xE0000000
Address 3 (memory) 0xF0000000
Address 5 (port) 0x0000E000
Subvendor ID 0x10DE
Subsystem ID 0x1132
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.2
PCI capability
Caps offset 0x68
PCI capability
Caps offset 0x78
Device type Legacy PCI-E Endpoint Device
Port 0
Version 2.0
Link width 8x (max 16x)
Caps offset 0x100
Caps class 0x18
Caps offset 0x250
Caps class 0x1E
Caps offset 0x258
Caps class Power Budgeting
Caps offset 0x128
Caps class Advanced Error Reporting
Caps offset 0x420
Caps class Vendor Specific
Caps offset 0x600
Vendor ID 1
Size 36
Caps class 0x19
Caps offset 0x900
PCI registers
00 DE 10 C2 17 07 00 10 00 A1 00 00 03 10 00 80 00
10 00 00 00 F6 0C 00 00 E0 00 00 00 00 0C 00 00 F0
20 00 00 00 00 01 E0 00 00 00 00 00 00 DE 10 32 11
30 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
40 DE 10 32 11 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
60 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 00 12 00 E1 8D 2C 01
80 10 29 09 00 03 31 45 00 40 01 81 10 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 13 08 04 00
A0 00 04 00 00 0E 00 00 00 03 00 07 00 00 00 00 00
B0 00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
F0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 02 00 01 25 00 00 00 00 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 04 00 01 42 00 00 00 00
130 21 81 07 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0FB0
Revision ID 0xA1
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF7080000
Subvendor ID 0x10DE
Subsystem ID 0x1132
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0x60
Caps version 1.2
PCI capability
Caps offset 0x68
PCI capability
Caps offset 0x78
Device type PCI-E Endpoint Device
Port 0
Version 2.0
PCI registers
00 DE 10 B0 0F 06 00 10 00 A1 00 03 04 10 00 80 00
10 00 00 08 F7 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 DE 10 32 11
30 00 00 00 00 60 00 00 00 00 00 00 00 11 02 00 00
50 00 00 00 00 00 00 00 00 CE D6 23 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 00 02 00 E1 8D 2C 01
80 00 29 00 00 03 31 45 00 03 01 81 10 00 00 00 00
A0 00 00 00 00 0E 00 00 00 00 00 01 00 00 00 00 00
100 00 00 00 00 00 00 00 00 00 00 00 00 30 20 46 00
110 00 20 00 00 00 A0 00 00 00 00 00 00 00 00 00 00
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x17C2
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF4000000
Address 1 (memory) 0xC0000000
Address 3 (memory) 0xD0000000
Address 5 (port) 0x0000DC80
Subvendor ID 0x10DE
Subsystem ID 0x1132
Int. Line 0x11
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.2
PCI capability
Caps offset 0x68
PCI capability
Caps offset 0x78
Port 1
Version 2.0
Caps offset 0x100
Caps class 0x18
Caps offset 0x250
Caps class 0x1E
Caps offset 0x258
Caps offset 0x128
Caps offset 0x420
Caps offset 0x600
Vendor ID 1
Size 36
Caps class 0x19
Caps offset 0x900
PCI registers
00 DE 10 C2 17 06 00 10 00 A1 00 00 03 10 00 80 00
10 00 00 00 F4 0C 00 00 C0 00 00 00 00 0C 00 00 D0
20 00 00 00 00 81 DC 00 00 00 00 00 00 DE 10 32 11
30 00 00 00 00 60 00 00 00 00 00 00 00 11 01 00 00
80 10 29 09 00 03 31 45 01 40 01 81 10 00 00 00 00
B0 00 00 00 00 09 00 14 01 01 00 10 0D 60 21 76 04
C0 60 21 76 04 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 2 (0x02), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0FB0
Revision ID 0xA1
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF5080000
Subvendor ID 0x10DE
Subsystem ID 0x1132
Int. Line 0x12
Int. Pin 0x02
PCI capability
Caps offset 0x60
Caps version 1.2
PCI capability
Caps offset 0x68
PCI capability
Caps offset 0x78
Port 1
Version 2.0
PCI registers
10 00 00 08 F5 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 60 00 00 00 00 00 00 00 12 02 00 00
80 00 29 00 00 03 31 45 01 03 01 81 10 00 00 00 00
Location bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B21
Model ID 0x0612
Revision ID 0x02
PI 0x01
SubClass 0x06
BaseClass 0x01
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000C050
Address 1 (port) 0x0000C040
Address 2 (port) 0x0000C030
Address 3 (port) 0x0000C020
Address 4 (port) 0x0000C000
Address 5 (memory) 0xF7300000
Subvendor ID 0x1043
Subsystem ID 0x858D
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x78
Caps version 1.2
PCI capability
Caps offset 0x80
Port 1
Version 2.0
Caps offset 0x100
PCI registers
00 21 1B 12 06 00 04 10 00 02 01 06 01 10 00 00 00
10 51 C0 00 00 41 C0 00 00 31 C0 00 00 21 C0 00 00
20 01 C0 00 00 00 00 30 F7 00 00 00 00 43 10 8D 85
30 00 00 00 00 50 00 00 00 00 00 00 00 13 01 00 00
40 00 00 00 00 60 61 11 02 00 00 00 00 00 00 00 00
50 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 11 78 01 00 00 00 00 00
70 00 00 00 00 00 00 00 00 01 80 03 00 03 00 00 00
80 10 00 12 00 02 87 90 05 00 28 00 00 12 F4 00 01
90 40 00 12 10 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 17 00 00 00 00 00 00 00 00 00 00 00
B0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 63 00 00 00
F0 FF FF 00 00 10 00 00 00 00 00 00 00 00 00 00 03
100 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 5 (0x05), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x144D
Model ID 0xA800
Revision ID 0x01
PI 0x01
SubClass 0x06
BaseClass 0x01
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 5 (memory) 0xF7210000
Subvendor ID 0x144D
Subsystem ID 0xA811
Int. Line 0x12
Int. Pin 0x01
PCI capability
Caps offset 0x40
Caps version 1.2
PCI capability
Caps offset 0x70
Port 0
Version 2.0
Link width 2x (max 4x)
PCI capability
Caps class Virtual Product Data
Caps offset 0xD0
Caps offset 0x100
Caps class Device Serial Number
Caps offset 0x140
Caps offset 0x150
Caps class 0x18
Caps offset 0x160
PCI registers
00 4D 14 00 A8 06 00 10 00 01 01 06 01 10 00 00 00
20 00 00 00 00 00 00 21 F7 00 00 00 00 4D 14 11 A8
30 00 00 00 00 40 00 00 00 00 00 00 00 12 01 00 00
40 01 70 C3 C1 00 00 00 00 00 00 00 00 00 00 00 00
50 05 00 00 01 00 10 00 00 00 00 00 00 00 00 00 00
70 10 D0 02 00 C1 8F E8 17 00 28 10 00 42 6C 47 00
80 40 00 22 10 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 10 08 00 00 00 04 00 00 06 00 00 00
A0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 01 00 02 14 00 00 00 00 00 00 40 00 30 20 46 00
110 00 00 00 00 00 60 00 00 A0 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version 2601
date 03/26/2015
ROM size 8192 KB
DMI System Information
manufacturer ASUS
product All Series
version System Version
serial System Serial Number
UUID {6AFFEC80-D7DA-11DD-9F68-7824AF326939}
SKU All
family ASUS MB
DMI Baseboard
vendor ASUSTeK COMPUTER INC.
model MAXIMUS VII HERO
revision Rev 1.xx
serial 140526607701728
DMI System Enclosure
manufacturer To Be Filled By O.E.M.
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Port Connector
designation KBMS (internal)
designation KBMS (external)
port type Parallel Port PS/2
connector PS/2
DMI Port Connector
designation USB_78 (internal)
designation USB_78 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB3_34 (internal)
designation USB3_34 (external)
port type USB
DMI Port Connector
designation USB3_56 (internal)
designation USB3_56 (external)
port type USB
DMI Port Connector
designation LAN (internal)
designation LAN (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation AUDIO (internal)
designation AUDIO (external)
port type Audio Port
DMI Port Connector
designation SPDIF_O_HDMI (internal)
designation SPDIF_O_HDMI (external)
port type Video Port
DMI Port Connector
designation VGA_DVI (internal)
designation VGA_DVI (external)
DMI Port Connector
designation SATA6G_12 (internal)
DMI Port Connector
designation SATA6G_34 (internal)
DMI Port Connector
designation SATA6G_56 (internal)
DMI Port Connector
designation SATA6G_E12 (internal)
DMI Port Connector
designation M2_TYPE_M (internal)
DMI Port Connector
designation USB3_E12 (internal)
port type USB
DMI Port Connector
designation USB910 (internal)
port type USB
DMI Port Connector
designation USB1112 (internal)
port type USB
DMI Port Connector
designation USB13 (internal)
port type USB
DMI Port Connector
designation TPM (internal)
DMI Port Connector
designation SPDIF_OUT (internal)
DMI Port Connector
designation AAFP (internal)
connector Mini Jack (headphones)
DMI Port Connector
designation CPU_FAN (internal)
DMI Port Connector
designation OPT_FAN (internal)
DMI Port Connector
designation CHA_FAN1 (internal)
DMI Port Connector
designation CHA_FAN2 (internal)
DMI Port Connector
designation CHA_FAN3 (internal)
DMI Port Connector
designation CHA_FAN4 (internal)
DMI Extension Slot
designation PCIEX1_1
type A5
populated yes
DMI Extension Slot
designation PCIEX16/X8_1
type A5
populated yes
DMI Extension Slot
designation PCIEX1_2
type A5
populated no
DMI Extension Slot
designation PCIEX8_2
type A5
populated no
DMI Extension Slot
designation PCIEX1_3
type A5
populated yes
DMI Extension Slot
designation PCIEX4_3
type A5
populated no
DMI OEM Strings
string[0] To Be Filled By O.E.M.
string[1] To Be Filled By O.E.M.
string[2] NERO
string[3] To Be Filled By O.E.M.
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 32768 MBytes
max# of devices 4
DMI Memory Device
designation DIMM_A1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 8192 MBytes
DMI Memory Device
designation DIMM_A2
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 8192 MBytes
DMI Memory Device
designation DIMM_B1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 8192 MBytes
DMI Memory Device
designation DIMM_B2
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 8192 MBytes
DMI Processor
manufacturer Intel
model Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
clock speed 4011.0 MHz
FSB speed 100.0 MHz
multiplier 40.0x
Storage
Drive 0
Device Path \\?\scsi#disk&ven_samsung&prod_ssd_850_pro_1tb#4&268c595a&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name Samsung SSD 850 PRO 1TB
Capacity 953.9 GB
SMART Support Yes
Drive 1
Device Path \\?\scsi#disk&ven_wdc&prod_wd2003fzex-00z4s#4&268c595a&0&010000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name WDC WD2003FZEX-00Z4SA0
Capacity 1863.0 GB
SMART Support Yes
Drive 2
Device Path \\?\scsi#disk&ven_samsung&prod_mzhpu512hcgl-000#5&16cdfafe&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name SAMSUNG MZHPU512HCGL-00004
Capacity 476.9 GB
SMART Support Yes
USB Devices
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x1B1C, product=0x0C04
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC03D
USB Device Xbox 360 Controller for Windows, class=0xFF, subclass=0xFF, vendor=0x045E, product=0x028E
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8009
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8001
Graphics
Number of adapters 2
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTX TITAN X
Board Manufacturer NVIDIA Corporation
Revision A1
Memory size 4095 MB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x10DE)
Model ID 0x17C2 (0x1132)
Performance Level 2D Desktop
Core clock 405.0 MHz
Memory clock 405.0 MHz
Performance Level Default
Memory clock 810.0 MHz
Performance Level 3D Applications
Core clock 595.0 MHz
Memory clock 3300.0 MHz
Memory clock 3505.0 MHz
Display adapter 1
Revision A1
Memory size 4095 MB
PCI device bus 2 (0x2), device 0 (0x0), function 0 (0x0)
Win32_VideoController AdapterRAM = 0xFFF00000 (4293918720)
Win32_VideoController DriverVersion = 9.18.13.5012
Win32_VideoController DriverDate = 04/08/2015
Monitor 0
Model ROG PG278Q ()
ID ACI27B1
Serial #ASNGFEML0ePd
Manufacturing Date Week 45, Year 2014
Size 27.2 inches
Max Resolution 2560 x 1440 @ 59 Hz
Horizontal Freq. Range 30-210 kHz
Vertical Freq. Range 30-150 Hz
Max Pixel Clock 540 MHz
Gamma Factor 2.2
Software
Windows Version Microsoft Windows 8.1 (6.3) 64-bit (Build 9600)
DirectX Version 11.0
