memory stick prob...
3 Jun 2008
When i put the memory stick in the usb port nothing appens normal thing is a window opens with sevaral options,so when i select drive e from my computer its say drive is not formatted format now yes/no..
Same thing appens when i try to access files in windows explorer,drive is not formatted format now yes/no
any idea's
Sounds like you didn't remove the drive "safely" last time you used it :( However this has happened to me before and I swear I removed it safely too.
