I'm looking at swapping my memory out but not sure which to go for, if at all.
The reason for swapping is due to my current memory only being Intel XMP Memory and I have an AMD system - AMD EXPO (not sure if this makes a difference).
I'm looking at the following;
CORSAIR VENGEANCE® RGB 64GB (2x32GB) DDR5 DRAM 6000MT/s CL30 AMD EXPO & Intel XMP Memory Kit (CMH64GX5M2B6000Z30)
The speed of my current memory is faster at 6400 MT/s but the new memory is only 6000 MT/s is it even worth swapping out or should I just stick with current memory and buy two additional modules to make 64GB total.
The supported RAM for my mainboard on the corsair website shows;
www.corsair.com
Thanks in advance.
▪︎ MSI MAG X670E TOMAHAWK WIFI
▪︎ AMD RYZEN 9 7900X3D RETAIL
▪︎ Noctua NH-U9S Intel/AMD Slim CPU Cooler 125mm
▪︎ Corsair Vengeance Black 32GB 6400MHz DDR5 KIT 2x16GB (CMK32GX5M2B6400C32)
▪︎ MSI NVIDIA GeForce RTX 4070 SUPER 12GB VENTUS 2X OC Ada Lovelace GPU
▪︎ Corsair MP700 PRO 1TB M.2 PCle Gen5 x4 NVMe 2.0 SSD
▪︎ Corsair RMe Series 1000 Watt Compact Fully Modular 80+ Gold PCIe5 PSU
▪︎ Fractal Pop XL Silent Black Full Tower PC Case
VENGEANCE® RGB 64GB (2x32GB) DDR5 DRAM 6000MT/s CL30 AMD EXPO Memory Kit
Attain top DDR5 RAM performance optimized for AMD® motherboards, with ten-zone RGB for DDR5 memory that lights up your cutting-edge PC.
Thanks in advance.
