- 23 Aug 2006
- North Wales
Hi i have asus commando mother board with 2 gig of ram (OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK))
I am using pc probe 2, apart from it showing me the temp of the cpu it also shows a temperature for MB. Does MB mean the temperature of my memory? and if so, is 38-41c idle and 47-51c when playing games ok? If not do you think i should get a memory cooler or is there another way to lower the temperature?
Thanks
Thanks
