Memory temps?
28 Jun 2004
Sheffield
Does there exist a program to tell you the temperature of the memory?
I've been having a few BSODs recently and I'm suspecting the memory overheating - it's very hot to the touch. I've got a spare 120mm fan lying around somewhere that I can set up to blow over the memory, but I was wondering if there was some way I could find out exactly how hot it is?
(Memory is 2GB of Geil Value DDR in an Abit NF7-S v.2 with a 2500XP-M at 11x200 and everything else is relatively cool MB:29 CPU:39 GPU:43 at idle.)
There are no thermal sensors on the memorychips.
Only way to rule out memory overheating is using a fan to actively cool them and see if that helps with stability.
My old Ballistix were roasting as well, I had to cool them with a 80mm fan blowing onto them.
Yeah, I thought that might be the case.
Anyway, I've hung a 120mm Akasa Amber blowing on to the memory and the system seems perfectly stable now. In fact, it may be my imagination, but I think that the whole computer has just become more reponsive, even the internet! :confused: :eek: :cool:
Maybe the hot memory wasn't performing ideally causing even more instability that you did not see in the form of a BSOD?
