Memory Timing Problems on MSI K8N Neo2 Platinum
24 Apr 2006
High Wycombe
Im having memory timing problems on the above mainboard.
Noticed it was running a bit slow and found that although it was running in dual channel mode, I was only getting 52% bandwidth efficiency, and bandwidth scores of ~2,300MB/sec, way lower than it should be. Anyway, I upped the speed to DDR400 with lowest memory settings, and it won't post. All modules should be capable of this, and were running at DDR400 in my old A7V880. Anyone have any ideas why Im having memory problems?
These are the timings for the individual modules from SANDRA:
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 16GB
Bank0/1 - A0 : DIMM 256MB/64
Bank2/3 - A1 : DIMM 256MB/64
Bank4/5 - A2 : DIMM 512MB/64
Bank6/7 - A3 : DIMM 512MB/64
Logical/Chipset 2 Memory Banks
Bank 0 : 512MB DDR-SDRAM 2.5-3-3-7 1CMD
Bank 2 : 512MB DDR-SDRAM 2.5-3-3-7 1CMD
Bank 3 : 512MB DDR-SDRAM 2.5-3-3-7 1CMD
Channels : 1
Speed : 2x 157MHz (314MHz data rate)
Multiplier : 1/14x
Width : 128-bit
Refresh Rate : 6.00µs
Power Save Mode : No
Fixed Hole Present : No
Memory Module 1
Manufacturer : Corsair
Model : CMX256A-3200C2
Type : 256MB DDR-SDRAM
Technology : 8x(32Mx8)
Speed : PC3200U 2.5-3-3-8
Date of Manufacture : 25 December 1999
Set Timing @ 200MHz : 2.5-3-3-8
Set Timing @ 167MHz : 2.0-3-3-7
Memory Module 2
Manufacturer : Kingston
Model : K
Serial Number : 00181000
Speed : PC2700U 2.0-2-2-5
Date of Manufacture : 19 March 2003
Set Timing @ 167MHz : 2.0-2-2-5
Memory Module 3
Manufacturer : Nanya
Model : M2U51264DS8HC3G-5T
Serial Number : C9741F13
Type : 512MB DDR-SDRAM
Technology : 16x(32Mx8)
Speed : PC3200U 3.0-3-3-8
Version : 1.0
Date of Manufacture : 06 May 2006
Set Timing @ 200MHz : 3.0-3-3-8
Set Timing @ 167MHz : 2.5-3-3-7
Memory Module 4
Serial Number : E9741F13
Version : 1.0
Thinking about it, this should prob be in Memory rather than Motherboards, so now moved it. Can you delete posts?
Are you running a Venice core A64 or newer? If not you will only beable to run 4 DIMMS at 2T at 166Mhz. If you are running a Venice or newer you will beable to run 4 x DIMMS at 2T at 200Mhz.
Im running an Athlon 64x2 4200+ (Manchester Core). Not sure where this core stands in relation to the Venice core. Lost touch a little bit on the code names, but I guess given that it's a X2, it is atleast comparable. Please correct me if I'm wrong.
