Memory timing Q
Depends on the chips being used I suspect.
BH5 chip settings will be different to TCCD chips which will be different to Infineon chip etc etc.
Normally its a stability thing at higher FSB!
ok this is my opinion, so others may disagree,
without going into detail the best number for your tras, is your cas (rounding up to a whole number), + trcd +2
therefore if you have 2-2-2 optimum is 6 for 2-2-2-6 or in your case 2.5-3-3 optimum = 3 (2.5 rounded up) +3 +2 =8 for 2.5-3-3-8
if you want an explaination on why i think this just say :]
ok i feel i need to back myself up, heres a section of an article from mushkins website on cas,tras,etc timings: (it also explains what the magical +2 is for :))
"....What is tRAS and why is it backwards and important at the same time?
The word latencies is generally used to describe a delay. However, Merriam-Webster defines the word’s origin as period of dormancy and in technical parlance, latency is often used to describe simply the duration of any event. One example is the PCI latency which describes the time any device has access to the PCI bus before it will be automatically disconnected to allow other devices access to the same resources. Why are we talking about this? Very simple, the access latencies of any device to the PCI bus are usually eight cycles, but the total latency can be set from 16-256 cycles. This shows that the same word is used to describe two entirely different parameters, the first being the time until any transactions can start, the second referring to the time that is available for transactions (minus the access latencies). As an example, a PCI latency of 32 will carry a penalty (access latency) of 8 cycles which leaves 24 cycles for actual data transfers. Therefore, decreasing this latency will not increase performance, on the contrary. The exact same is true for tRAS short for the RAS Pulse width. Historically, tRAS was defined as the time needed to establish the necessary potential between a bitline pair within the memory array until it was safe to write back the data to the memory cells of origin after a (destructive) read. Pay attention to the word read here. Memory, in many ways is like a book, you can only read after opening a book to a certain page and paragraph within that particular page. The RAS Pulse Width is the time until a page can be closed again. Therefore, just by definition, the minimum tRAS must be the RAS-to-CAS delay plus the read latency (CAS delay). That is fine for FPM and EDO memory with their single word data transfers. With SDRAM, memory controllers started to output a chain of four consecutive quadwords on every access. With DDR, that number has increased to eight quadwords that effectively are two consecutive bursts of four. Now imagine someone closes the book you are reading from in the middle of a sentence. Right in your face! And does it over and again. This is what happens if tRAS is set too short. So here is the really simple calculation: The second burst of four has at least to be initiated and prefetched into the output buffers (like you get a glimpse at the headline in a book) before you can close the page without losing all information. That means that the minimum tRAS would be tRCD+CAS latency + 2 cycles (to output the first burst of four and make way for the second burst in the output buffers). Any tRAS setting lower tRCD + CAS + 2 cycles will allow the memory controller to close the page “in your face!” over and again and that will cause a performance hit because of a truncated transfer that needs to be repeated. Along with those hassles comes the self-explanatory risk for data corruption. That one is not a real problem as long as the system is kept running but in case it is shut down and the memory content is written back to the hard disk drive, the consequences can be catastrophic. For the drive, that is.
What does this spec mean?
Take for example 2.5-4-4 as the latency rating for a module. Latency is a measure of delay, that means the 2.5 rating in 2.5-4-4 indicates a 2.5 clock cycle delay. And the 4 ratings mean a 4 clock cycle delay. The clock cycle delays that these ratings are measuring is what determine how long it takes your CPU to write or remove data from memory. So the lower these latencies are, the less time your CPU spends idle waiting for data which results in higher performance. The position of the rating in 2.5-4-4 determines what latency the rating is referring to. The ratings, in order, represent the latency ratings for CAS, tRCD (RAS-to-CAS delay), and tRP (RAS Precharge). It would take a long time to explain what each of these latency ratings means, so to make a long story short the lower the latency the higher the performance of your CPU.
Why do some manufacturers indicate faster speed and/or lower latencies than Mushkin?
We make sure that all our modules run at the specified speed rating and above by a substantial margin. Many companies just meet the specs under optimal conditions, for instance with only one module installed. Keep in mind when looking at module ratings whether the company selling them rates them according to their abilities under heavy load on various chipsets. Meaning that these ratings need to represent what the module is capable of when installed with all the DIMM slots in various motherboards filled, which is what we do. Unscrupulous or naive memory resellers on the Internet will rate their modules by what they're capable of when running by themselves and on certain chipsets. Memory modules are generally capable of faster speeds and lower latencies when only one module is installed and on certain chipsets. So while it may look like their memory is faster than ours, in actuality they just came up with their ratings from ideal conditions that aren't representative OF ALL real world scenarios.So their memory isn't necessarily better than ours, they just have lower standards FOR rating their modules.Companies LIKE this will also have misleading tech support(i.e.It ' s your fault, NOT ours WHEN the modules won't run AS rated), AND poor refund policies WITH hefty restocking fees WHEN you want TO RETURN a module. ...."
