Hey all
I've Overclocked my computer buton prime95 a worker stops after about 2 hours, I've done my research and im pretty sure its the memory as the only thing ive touched is the memory voltage... Its running at 1600 and 1.650V? Any ideas of what i need to change timing wise? Or anything else.... here are the rest of my settings:
CPU: 4.0ghz 1.4250V
NB: 2400mhz 1.4v
HT: 2400mhz AutoV
Memory: 1600mhz 1.650V
Memory is Geil Corsa Dual Channel 1866 by the way
Thanks in advance
I've Overclocked my computer buton prime95 a worker stops after about 2 hours, I've done my research and im pretty sure its the memory as the only thing ive touched is the memory voltage... Its running at 1600 and 1.650V? Any ideas of what i need to change timing wise? Or anything else.... here are the rest of my settings: CPU: 4.0ghz 1.4250V
NB: 2400mhz 1.4v
HT: 2400mhz AutoV
Thanks in advance
