I have just read the FAQs and another memory timings thread, but rather than hijack any of these I have a few queries based on wanting to improve my timings and performance.
I have a set of Corsair 2GB DDR XMS3500LL Pro TwinX (2x1GB) running in an Asus A8N SLi deluxe with an FX-57
currently I have the system set as follows:
FX-57 - 15x200 - 3GHz
Memory - DDR400
2.5 CAS
6 Tras
3 Trcd
3 Trp
11 Trc
13 Trfc
4 Trwt
3 Twr
1t Timing
System is on Air and is currently stable and not running hot. My questions are:
1) Can I change the memory speed from DDR400 to 433 safely?
2) What can I then change the memory timings to? (and which do I ignore?)
3) do I need to match settings, or change one thing at a time?
these are probably extremely noobish questions, and for that I apologise, but while I've had experience with clocking CPUs and GPUs, I've never ever changed the memory. I'm aware that it will give an increase in performance and would like to squeeze my system a little.
thanks in advance for any answers
Memory - DDR400
2.5 CAS
6 Tras
3 Trcd
3 Trp
11 Trc
13 Trfc
4 Trwt
3 Twr
1t Timing
It should run fine. Set it to that at the default voltage and run memtest. If it fails, RMA it for not running at specified speeds.
