Memory timings question
23 Aug 2006
North Wales
Hi i do not know that much about memory timings but i was wondering if the higher the timings the better or the lower the timings the better ?
I have 2GB of OCZ PC2-6400C4 DDR2 and i have noticed in the bios that my timings are 5-6-6-15 now is that ok or should i lower or higher them to get better performance or just leave them as they are ?
Thanks
The lower the timings the better, i think your RAM should be running at 4-4-4-12 so I'd try lowering them in your Bios. You probably wont see much of a performance boost apart from benchmarks, but real world performance, very little.
