- 29 Sep 2004
- Hull, UK
I've got some Corsair 2GB DDR XMS3200C2PT TwinX (2x1GB) which is capable of running timings 2-3-3-6. My motherboard is a Gigabyte K8N51GMF-9 nForce 430 but there are no options in the BIOS to change the timings and CPUZ indicates they are at 3-3-3-8.
Is there another way I can change the timings? Would it be a significant performance boost anyway?
Bearing in mind I can get it to 215mhz no problem, which ups CPU from 2.2Ghz to just under 2.4.
Any help will be much appreciated.
