Memory Timings
There is a way you can speed that memory up :)
and also speed up your system and make it more stable.
set your system to a 1/1 devidor giving your memory 800Mhz
and set the timeings 4.4.4.12 @T1 with 2.25v
if you get errors set your memory to T2...
this in theory will give your system a even more speedy kickstart. :)
Wouldnt 2.25v with my current memory be risky as it is suppost to run at max 2.1v?
Dominators should run perfectly fine at 2.25v
you dont really need to run at 2.25v unless you can hit the T1 timeing ;) if your at T2 then 2.1v is perfectly fine ;)
I have 4x 2048 corsair 6400C4 DHX, currently running at 2.1v 4-4-3-12 (ddr800)performance level 8. Should these also be capable of 1T with a little more voltage ? or is 4 sticks likely to be to much of a strain on the nb.
