Hi thanks for looking.
I'm currently trying to get my corsair vengeance rgb pro 3600 to work properly.
I know with my ryzen 7 2700x 3600 is impossible and as the only auto config in d.o.c.p is 3600 I'm having to imput the timings manually to run at 3400mhz.
Currently they are 17,17,17,39 which is what corsair recommended for that speed. The system is a lot more stable but I'm still getting a lot of memory errors when gaming!
I'm unsure what timing I'm ment to input. In my bios I can change cas, rcd, rp, and ras but corsair also mention rc, faw, rrds, and rrdl which is set on auto. Do I need to change them aswell or leave on auto?
Thanks.
Also I can't change the dram voltage. Corsair recommended 1.35v but it's set to 1.20v and I can't change it.
I forgot to add its a asus rog strix b450f gaming board.
Thanks.
