Memory unstable at rated...
Man of Honour
4 Jul 2008
..timings and voltage.
Got a 3x2gb 1600 8-8-8-24 kit from Patriot. Problem is, I'm always getting random lockups and restarts when I set it to this.
To counter this, I set the memory multiplier to x6 rather than x8, so it's now running at 1200mhz only. I've dropped the timings to 6-6-6-18 to make up for the lower frequency, and it's running stable as a rock (thus far).
So I'm wondering, whats causing the instability at rated timings and voltage?
Could it be my CPU's memory controller just not being up to par, or a possible faulty stick? I'm completely happy running it at 1200 because as mentioned, it's a lot lower latency now also and from what I can tell, theres no visible difference. I'm just trying to get to the bottom of a problem ;)
did you put enough voltage through it for the stock settings. I've certainly had boards that at stock undervolted ram.
Indeed I did, tried 1.66, as my board doesnt have 1.65 as an option. Also tried 1.68, no dice.
Didn't want to go any higher as the CPU are sensitive to DRAM voltage I believe.
You could have a faulty memory module, setup the ram st recommended settings and download and run Mem-Test to double check your ram for errors.
