Memory Upgrade 2GB - 4GB. Help required please
8 Oct 2007
Hi,
This might be a fairly simple and obvious question for people who know (which unfortunately isn't me), But could someone please advise if it is possible to upgrade the memory on my pc from its current 2gb of memory to 4gb?
Below is some information that might help you to detect whether an upgrade is possible for my pc:
Processor: Intel Core 2 Duo CPU E4500 @ 2.20GHz
Motherboard: Foxconn 45GM/45CM
Bios: Phoenix Technologies V 6.00
Chipset: Intel i945G/GZ
General Memory Information :
A0 (RAS 0, RAS 1) : 1024 (Double Bank)
A1 (RAS 2, RAS 3) : 1024 (Double Bank)
Information SPD EEPROM (A0) :
Manufacturer : Unspecified
Part Number : Unspecified
Serial Number : Unspecified
Type : DDR2-SDRAM PC2-5300 (333 MHz)
Format : Regular UDIMM (133.35 x 3)
Size : 1024 MB (2 ranks, 4 banks)
Module Buffered : No
Module Registered : No
Module EPP : No
Width : 64-bit
Error Correction Capability : No
Max. Burst Length : 0
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 1.8v
Prefetch Buffer : 4-bit
Manufacture : Week 0 of 2000
Supported Frequencies : 200 MHz, 266 MHz, 333 MHz
CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz, 15 clocks @333 MHz
Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz, 20 clocks @333 MHz
Information SPD EEPROM () :
Module EPP : No
Width : 64-bit
Voltage : SSTL 1.8v
Memory Controller Information :
Memory Controller : System Memory
Number of connectors : 2
Max. Module Size : 2048 KB
Hope this helps, any advice would be very helpful.
Thanks,
Alan
Hi and welcome to the forums :)
Depends if it's the 45GM or the 45CM version.
The 45GM can take 2x2gb, whilst the 45CM can only take 2x1gb.
Download CPU-Z and see what its Motherboard tab says.
Hi Cob.
Thanks for the welcome and reply. :)
Unfortunately, the CPU-Z program is stating the same information that i posted before. It says: model 45GM/45CM.
Which seems a bit stupid if one can be upgraded to 4GB and one can only be 2GB and its not differentiating between the two!
Is there any other way that i might be able to find out which model mine is?
Meh I was hoping it it would be a Packard Bell. They let you find out the motherboard model.
Your best (and maybe only) hope is to see if the motherboard has the model printed on it.
