Memory Upgrade 3200/3600
2 Jun 2009
UK
Currently running a 5600x but going to upgrade to a 5800x3d in the next few weeks and was thinking of adding another 16Gb in at the same time. At the moment I have 2x8Gb of Corsair Vengeance 3200, is it worth just getting a matching set of 2x8gb or better to upgrade to a 2x16Gb 3600 set?
MB is a B450 Tomahawk
It’s probably not worth the extra cash for 32gigs of RAM.
You won’t really notice the difference unless you’re running out of RAM with 16gigs.
5800X3D is a nice upgrade though, that’s worth it.
I've just upgraded my ram from 2 x 16gb Patriot viper 3200mhz to Corsair Vengeance rgb pro 2 x 32gb 3600mhz. Same 5800x3d cpu andB450 Tomahawk max mboard. They seem to be working ok and at the correct speeds.
