memory upgrade advice required
2 Oct 2004
N.W London
Hi there
I have an Asus UX303LA-R4338H laptop that currently has 6gb and would like to upgrade the RAM.
Can someone kindly confirm the following for me please?
a) I can upgrade to 12gb ram only - maximum?
b) The 6gb is soldered onto the motherboard cant be sure, how can i tell without taking the back cover off?
c) if option b is true then there is no point in purchasing a 8gb memory stick? I would be better off going with the 4gb memory stick?
d) if option b is false then I can purchase 8gb and 4gb memory sticks to max it out, is that right?
finally I believe i need ddr3 pc3-12800 1600mhz 204-pin SODIMM is that correct?
if yes can you spec me some decent stuff, I dont care if its cheaper and a few milliseconds out, looking for bang for buck
thank you so much
