Hey all,
Im currently running 4x1gig of OC UK Value ram that i bought a few months ago. it was rated at 1066 but i was never able to run it at this. didnt bother me since i kept it on a 1:1 ration with my FSB. i was told this helps with overclocks at the time. but since then nobody else had said the same. (running 425x8 on a q6600 so thats running at 850mhz on the ram )
So im now concidering a ram upgrade. im looking at 2x2gig reaper OCZ ram currently hovering around the £73 mark. would it be worthwhile me getting this upgrade?
ive head that 2x2gig works better for OC than 4x1gig. and also id almost certainly be able to run at 1066mhz right?
any advice is greatfully accepted!
also note: i intend to water cool this rig shortly to try and get better OC on the cpu. so anything that help me achieve better clocks is a bonus!
edit: you may notice in my sig my ram timings are 4-5-4-6. this is what i managed to get them down too in the bios whilst still retaining 0% faults in memtest (ran too 500% on each stick individually and with all 4 sticks in using mutiple memtest instances)
