memory upgrade advice
2 Nov 2016
Hi everyone,
Long time shopper first time poster.
I have an "Titan Machete" Intel Core i7-4770K 3.50GHz Turbo Nvidia GeForce Gaming PC system with 8GB of RAM which i purchased March 2014 from Overclockers and i wish to upgrade this to a total 16GB.
The mother board is an Asus Z87-K.
I am not sure what memory is installed and which would compatible, can someone please advise me which RAM i need?
Thanks in advance.
Mark S
It will be ddr3 ram. Depending on how many dimm slots you have and the current configuration you may need to buy 8 or 16 gigs. If you buy 8 you will need to match the ram that you already have.
Typical ddr3 speed is 1600 but if you set xmp in your bios you can go much higher.
