Memory Upgrade DDR2-6400
24 Dec 2011
Googled your mobo:
4 x240-pin DIMM, Max. 8 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
So yes it will fit fine and work. I'd suggest buying used memory though, £50 is a lot to spend on DDR2, you can pick up the same for about £20 used.
