memory upgrade for macbook (Sept 07 model)
18 Oct 2005
I currently have two 512mb dimms in and was seeking to upgrade to the max of 2gb this macbook will take. Just wondering if anyone has used Crucial memory and if you would recommend it? Great price from OCUK at the minute, so just about to order :)
I think I have that in my MacBook at the moment, ordered it from OcUK about 18 months ago and works great :)
I installed and used the system checker on the manuf's site and noticed while the technical specs are the same the model numbers aren't. Will I be OK with the OCUK set or are these different sets of ram?
