Hello all.
I bought a pre over clocked system from Overclockers last year with the following specs:
Titan Exodus
I've noticed recently that the price of Memory seems to have dropped considerably and I can pickup 8GB for around £50. It would be good to have more since I use a lot of video/imaging software and a Linux VM running within windows 7. When I bought my system I did ask for a memory upgrade but the chap I dealt with said I would loose my overclock.
If I did go ahead and buy more memory would I need to completely manually redo all of the overclock settings including the CPU? In other words, would the detection of 8GB instead of 4GB memory upset everything or would I just need to re-tweak the memory config settings or optionally, leave it running as default?
If it all goes belly up and I want to re-install the original 4GB pair can I restore my original overclock settings from a 'known good' configuration file or is it a case of writing everything down before I start? Been checking around and I can see that it's possible to backup the BIOS to disk but it's not clear whether the settings will be saved with this nor if I can export and re-import BIOS settings.
Thanks in advance.
Titan Exodus
- P7P55D-E
- i5-760 running @4GHz
- 4GB Ram
- HD5850 GPU
Thanks in advance.
