Memory upgrade for x1800 but going TR
3 Dec 2005
UK
Hi,
I have the asrock itachi x370 and x1800 ryzen cpu. I have 32gb of ram at the moment 2x16gb but it was cheap and only really to get the system running. I feel this is the weak spot in the system as the cpu runs stock and the ram only allows slight adjustments before it become unstable (stock is fine).
I will be going Theadripper after Xmas but was wondering if it is worth changing the ram now then use it in the new TR build.
What ram would be best suited or is there any new ram changes coming.
Because of internal design Ryzen would benefit from faster memory, but thanks to DRAM maker cartel 32GB of faster DDR4 is darn expensive.
