Memory Upgrade Help!
1 Sep 2008
Hi Guys & Girls,
I have a Dell Dimension E520 which is currently running off 2 x 512MB DDR2 PC4300 533MHz!
As most of you know Vista needs a good 2GB of RAM.....and because of this my PC is running quite slow.
Do you think if i buy 3 of the below (aout £10 per stick) this would be sufficient? If you have any better ideas please leave me a link or write down the description and I would be grateful.
Corsair DDR2 PC4300 533MHz non ECC unbuffered CL4
I don't want to spend too much money as I just use the PC for internet, e-mails, photos, music etc and a spot of web design.
Thanks,
ManxMan
cheers for your help everyone (or lack of). I take it there is a OCUK forum 'click' that ya have to get in to in order to get a reply?
RAM has now been ordered......just hope its right now!
To be fair, you posted on the forums without reading the rules and wanted someone to recommend RAM from a competitors site, which no one could see after you [rightly] removed the link.
However that aside, the RAM you were looking at will do the job.......
