Memory Upgrade
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Hi Guys,
In light of the really cheap memory offers this week I'm looking to increase my box from 2GB to 4GB. The problem I think I may run into is my current 2GB is different from the one I'm interested in. Would these 2 different RAM sticks not work together at all?
The one I currently have is:
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA663)
The memory I'm looking to add is:
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
and if it helps my mobo is:
Asus P5K Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
Any help would be great thanks
should be fine.
i know people go on about compatibility and limiting an overclock/stability , but i've done it in the past and hardly noticed any difference.
