Memory Upgrade?
31 Oct 2007
Gods County(Allegedly)
Running a P5Q-E motherboard with Dominator 1066 ddr2 ram.
Am waiting 'new' Q9650 which I hope will clock to at least 3.6 if not 4.0 :D
My ? is wether there would be any benefit in swapping out the ram I'm using for 1200 PC2-9600 type.
I know that my Dominator does NOT like speeds above 1100. BUT not sure if faster ram would give me any 'real' benefit.
Members thoughts would be appreciated
None. The multipliar on your q9650 is x9, so 4ghz would be a minimum ram speed of 890mhz. Your ram is already faster than you need.
However, if what you have in mind is running faster than 1:1 with fsb, then I believe it makes a very small difference in games and calculations. I'd suggest getting it stable at 4ghz, higher if you can, then wondering if changing ram is needed. I think you'll be very happy with a 4ghz quad core, even if your ram is underclocked :)
