HAving spent all my budget on New Case, PSU and Fan controller (£260). my actual spec is fairly old. I'm running a Gigabyte GA-MA790X-DS4 mobo with an AMD 2.4Ghz Phenom 9750 Quad core Cpu. Memory is Kingston HyperX matched 2x2Gb 800 ddr2
I have just switched to Vista ultimate (I know win 7 is about to hit the streets)
and noticed that although My bios is showing 4gb Vista is showing 2.5Gb.
I booted back into XP Pro and had exactly the same results.
I've had the memory out, cleaned mobo etc. If I put either stick into slot 1 the bios and OS pick it up at 2Gb, as soon as I put a stick into slot 2 bios again shows 4gb Vista 2.5Gb. Has anyone any idea what is going on? Is vista mis-reporting and the biops sis correct? or whar?
Kelvin
Kelvin
