Having a few issues with a friends computer. Its been BSOD since 23/12. He done a restore on boxing day and it BSOD again on the 7th.
The computer was bought in October 2009, so its out of warranty.
I cant remember the first BSOD code, but the second was MEMORY_MANAGEMENT and the second was IRQL_NOT_LESS_OR_EQUAL.
Now because it was memory management, I assumed OS related. IRQL_NOT_LESS_OR_EQUAL relates to a peripheral not functioning properly/ BIOS fail or OD fail.
This has led me to believe its OS related.
Now because he said to me that it had memory issues, I took memtest on a pen and tested.
It got to 30% ish and failed with the following error:
"Memory error detected! Copying between f6520c2 and f65206a did not result in accurate copy.
MemTest has detected that your computer cannot accuratly store data in RAM.
You need to fix this."
This is now leading me to believe that RAM is an issue (with the second BSOD relating to memory).
Anyone have any ideas on the memtest codes?
Obviously the memory will have to be changed, but can anyone think of any potential problems with the information I gave?
