Memtest86+ 5.00 Alpha 1
19 Dec 2003
Grimsby, UK
Copied from another forum thread.
http://www.memtest.org/download/beta/500a1/mt500a1.bin
Memtest86+ V5.00a1 changelog
  • Added support for up to 2 TB of RAM on X64 CPUs
  • Added multi-threading (SMT) support up to 32 cores
  • Added complete detection for memory controllers.
  • Added enhanced Fail Safe Mode (Press F1)
  • Added CPU temperature reporting
  • Added support for Intel "Sandy Bridge-E" CPUs
  • Added support for Intel "Ivy Bridge" CPUs
  • Added preliminary support for Intel "Haswell" CPUs
  • Added support for AMD "Bulldozer" CPUs
  • Added support for AMD E-/C-/G-/Z- "Bobcat" CPUs
  • Rewriten lots of memory timings detection code
  • Corrected a lots of bugs
Known bugs (Mt86+ 5.00 alpha 1)
  • Time counter goes crazy due to SMT on Intel CPUs
  • Memory Bandwidth incorrect due to previous bug
  • IBM clusters & 4 Socket servers not supported (Proprietary SMT)
  • Fail Safe Mode doesn't disable SMT yet
  • Older platforms not validated yet. Don't expect something working !
  • AMD "Trinity" CPUs unsupported yet.
  • False positive on a 8-byte memory area near 0.4 MB due to a bug somewhere in the SMT trampoline code.
Download (raw binary - Best way to test : create an USB key with the 4.20 installer and replace mt86plus with this file) :
If you don't know how to use it, wait for Beta release !
Custom Alpha:
http://www.memtest.org/download/beta/500a1/mt500a1_madt.bin
http://www.memtest.org/download/beta/500a1/mt500a1_nosmp.bin
I uploaded 2 new revision of mt500a1, one with SMP MADT, another without SMP
stasio said:
Memtest86+ 5.00 Alpha 2
http://www.memtest.org/download/beta/500a2/mt500a2.bin
  • Added support for Intel Atom "Pineview" CPUs
  • Added SPD detection on AMD Chipset
