Memtest86+ v1.70
23 Apr 2004
UK, Near the middle......
A new version of Memtest86+ has been released.
New Features
Add new DMI polling feature
Add Support for Core/Core2 Solo/Duo/Quad CPU
Add Support for AMD K8 with DDR2 Memory
Add Support for Intel CPU with 192/384 KB L2 Cache
Add Support for FB-DIMM based memory (DMI)
Add Detection for ALI CyberAladdin-T (M1644)
Add Detection for Turion 64 X2
Add Support for ATi Radeon xPress 3200
Add Support for Intel i975X
Add Support for Intel Q965/P965
Add Support for Intel Q963/Q965
Bug Fixes
Force detection for AMD K8 with unknown chipsets
http://www.memtest.org/
have to try it from a bootable CD... tried it from my pen drive (which worked fine with previous versions) and just an almost empty bluescreen with a flashing cursor a couple of yellow bars and nothing else.
How does it work on a pen-drive?
I got a single file called 'mt170.exe' that doesn't do anything when clicked?
tried to boot from it but no joy (system is ok at booting from a thumb drive).
I used the HP utility to make the pen drive a bootable dos disc and put the mt170.exe on there... doesn't seem to work too well tho... so I guess I'm gonna be burning the iso to CD to try that.
Ok loaded it from floppy, seems ok?
Still doesn't pick up the 965 chipset or memory timings though?
Wouldn't mind knowing how your meant to boot it from USB?
