7 Apr 2009 at 20:35 #1 Phate Phate Caporegime Joined 1 Nov 2003 Posts 35,691 Location Lisbon, Portugal Hi Guys, I've got 2 Aperture Libraries, what is the best way to merge these? Many Thanks Jake
9 Apr 2009 at 23:27 #2 PardonTheWait PardonTheWait Soldato Joined 26 Aug 2003 Posts 24,282 You can actually just dig in the libraries (right click, show package contents) and move the .approject files out of them and into another
9 Apr 2009 at 23:46 #3 Phate Phate Caporegime OP Joined 1 Nov 2003 Posts 35,691 Location Lisbon, Portugal I took the long process, exported projects, copied over via wifi and imported them in the end Only 22gb of projects to import...nothing heavy
9 Apr 2009 at 23:52 #4 PardonTheWait PardonTheWait Soldato Joined 26 Aug 2003 Posts 24,282 Suit yourself
10 Apr 2009 at 00:03 #5 Phate Phate Caporegime OP Joined 1 Nov 2003 Posts 35,691 Location Lisbon, Portugal Mohinder said: Suit yourself Click to expand... You were toooo slow boyo!
10 Apr 2009 at 00:08 #6 PardonTheWait PardonTheWait Soldato Joined 26 Aug 2003 Posts 24,282 Not as slow as your library merging workflow BURN
10 Apr 2009 at 00:15 #7 Phate Phate Caporegime OP Joined 1 Nov 2003 Posts 35,691 Location Lisbon, Portugal Mohinder said: Not as slow as your library merging workflow BURN Click to expand... Pwned *hugs Mac Pro*
