Merging Boot and System partitions?
18 Oct 2002
melbourne
Here's the situation. For some reason, my laptop drive was partitioned into two by the previous owner. It has a C: drive and an E: drive. The E: drive contains Windows XP, programs and personal files. The C: is empty apart from the system files, eg ntldr, ntdetect.com. This is causing confusion as some files are being saved to C: and I have to keep manually moving them all to E:
I want to merge the two partitions and just have C: as the only drive. Is this possible? I can't format and reinstall because I have important programs that can't be reinstalled.
ps. I have Partition Magic if that helps.
Just a thought. If it's too messy to merge them, could I resize the C: partition to almost nothing, hide it, and then rename the drive letter on the E: partition to C:? Partition Magic seems to have tools to do this but I'm not sure if renaming the Windows XP drive will cause problems.
Many thanks
Changing the drive letter of a system drive will probably cause every program to stop working
I also wouldn't attempt this with partition magic if you've got important files and documents on there, as it has more of a habit than most programs for screwing things up in my experience.
If it were me, I wouldn't risk it if I couldn't re-install the programs.
If you do try anything, make a back up of both partitions before hand so you can go back to the way it was.
Many thanks
If you do that the system will no longer boot!
