Merging offline 360 gamertag with an online one
11 Apr 2006
Earth
Is there anyway to do this. I have only just got my console online and the gamertag i had offline, is not available online, and i have a different name for my online one?
help
When you choose the join Xbox live option from the blades, it lets you go through the process of signing but but allows you to change your tag if the offline one is allready in use. Your gamer score will all still be the same, but just your tag that's different
i think the only way you could do is it to convert your offline tag to an online one (see my previous post), then you'd have to use that tag as your main one. As has been said I don't think you can actually merge 2 tags together so all the achievements etc appear on the second tag
