Merom T7400ES QLZT oc...
9 Jun 2005
Heres out of the box straight to mobo's socket....with stock Aopen HSF/air:)
Aopen i975Xa-YDG stock vcore/disable vmod.
2X512 OCZ 5400EB
Trident PCI
Zippy 850W
Win XP no tweaks....
2M....
trojan698 said:
Nice, now get clocking! :p
He has overclocked it :confused:
Speedstep appears to be dropping the multi once Pi ends.
166*13=2158mhz (stock)
223*13=2899mhz (overclock)
223*6=1338mhz (speedstep with o/c fsb)
Nice score
Mul
Concorde Rules said:
Now do that on both cores at the same time, my X2 gets 28 sec @ 2.5ghz
Surely you mean 38... I hope you do then I can be smug :D
My 805 get 36-37 running 2 at once, regardless the merom would only be a few seconds slower.
It will be still fast though.
Good work there Sedatixie.
What air cooling you got?
Found any problems with the board? Get any further? Whats the max you got from it dual priming?
Thanks Bennah :) Its with stock Aopen hsf. I have to disable vcore mod since this one hate >1.52V.
I will torture it with cascade next:)
Hm.. going from a Stock HSF to a Cascade, cant be bad :D
That thing will fly on a cascade if you hit the sweet spot.
Got any gpu's you can play with the Merom ?
I wish I was one of the few beta testers but no not used one just seen the reveiws although 3.6 on chilled water for an fx62 aint too bad ??
depends if thats the ceiling, (like the disappointing fx -60s) it doesnt look very promising.
Unfortunatly a lot of hardcore ocers will be getting a conroe rig instead so we might not see massive clocks
