Hi, I'm new here so please go easy on my technical ignorance, I am hoping for some help, I have lots of questions but essentially I am trying to fix slow wifi. I have 4 Deco X20s. My first question is:
If I want to use a wired backhaul, what is the best method? Deco1 is wired to my ISP router. The second port in Deco1 is used to go to a 16 port switch. The other decos are then wired in to that switch. I could, if it is a good idea(?) wire some of the other decos directly to the ISP router too (thereby spreading the internet traffic through more ISP router ports - but I have no idea if this is good or bad.
The issue I am having is that my ISP router connection speed is 70/20 on both wired and wifi. My Deco mesh is really inconsistent, but an awful lot of the time I struggle to get 10/2. I would have thought that the deco system should be able to deliver pretty much the 70/20 that the ISP router does? (sometimes it does achieve those speeds, but not very often)
(I am upgrading my ISP next week to 300/100, so I guess any answers should consider that - is the Deco x20 system even suitable for me with the new connection, if not what would you recommend)?
Any help gratefully received. Thanks.
