- 15 Jul 2019
Good day.
I have recently built my first watercooling system, the thing is.. Components i bought were actually meant for another case which ended up being too tight for my taste so i bought this one.
For now i run a Nemesis GTS 360 up front, GTS 240 up front.
I have reversed rear fan for intake, and placed bottom intake as well and all rads are actually exhaust. I have 12 degree water\ambient delta and also 12 degree gpu\water delta which i think is fine i guess for the rad space i have? I will also try to put both rads for intake, and rear fan exhaust and see if it's chaning anything for better or worse. The GPU is 3080 with 350w limit and a 5800x. Ryzen is a very special boy when it comes to cooling, let's just say i ignore what temps it's showing but i did managed to shave off about 10 degrees compared to 240 AIO in peak load.
Fan noise is lower compared to my air cooled set up, but i am thinking of expanding with one less flow restrictive 360 rad instead of GTS 240. I am thinking of going thicker in front, like XSPC RX V3 or Black Ice SR2, i've tried to measure clearances, to me it looks like it will be a tight fit, i am not even sure rear fan fits if both 360 are not slim and i will have to lift the top panel to fill the res.. However i've seen people building dual 360 in Meshify S2 or Define 6 and they say layout is "similar", but i never witnessed a meshify 2 build. Maybe there are people around who actually did manage that? One thing that is important - i have aquacomputer ultitube 150 with 120mm fan mount, so i really want to mount it on the front rad.
