Quite a few Z690 Boards have pushed the socket further to the right
which caused issues with my Fractal Meshify 2
I fixed it with an Angle Grinder + Flap Pad
It would have been neater if my Dremel wasnt siezed its hard work with a huge flap pad
I spoke to fractal and they have been great and will be releasing a new revision at some point
anyway here's what i did to make it fit if it helps anyone
With Edging Trim 4 mm x 3 mm
