Meshify c , intake fan recomendation.
8 Oct 2018
Hello,
I'm looking for two 140mm. fans for front intake , i will use the two 120mm. fans that come with the case as back and top(?) exhaust.This case front filter is very dense.
I have inside evga gtx 1080ti SC2 , and overclocked i5 3570k with Be quiet dark rock 3. Right now its very hot with the stock fans both gpu and cpu are ~80c , if i remove the side glass panel both temps drop with ~10c.
Right now i'm looking at :
1. https://noctua.at/en/nf-p14s-redux-1200-pwm
2. https://www.bequiet.com/en/casefans/448
I'm open for any suggestion , performance/noise balance , 10-15euro per fan max with the noctua fan at the top end of the price.
Ocuk phanteks 140mp 2 pack.
Pressure is basically equal or better than any thing else up until 1400rpm and enough to overcomethe mesh. Got some myself on my meshify do the job wonderfully. Basically silent when browsing.
