- 19 Jan 2015
Evening
I'm looking to upgrade my case, currently have a Zalman Z9. I was thinking of going for the Fractal Meshify C as I had seen it has good airflow. But looking further it seems it needs more fans to achieve this, but I do have 4 Corsair AF120's already, so 3 intake one exhaust all good. Thing is the Zalman has a fan hub but the meshify doesn't, the motherboard I have only has 3 fan headers.
So can I use this fan hub, or is there another case you would recommend that would get me around this?
https://www.overclockers.co.uk/phanteks-pwm-fan-hub-black-ca-009-pt.html
I should say also that I have currently a GTX 1060 and GTX 970 as I do some casual mining so needs enough space verticially in the case for these. Also the CPU cooler is a Coolermaster hyper 212. I would say airflow is the most important thing but I don't want it to be as loud as an aircraft either
Thanks
Thanks
