Hello.i am looking for some advice.regarding the ssup Meshlicious case. Does anyone know if the Msi 3070 gaming z trio will fit into this case.i would like to upgrade from my next h1 V2. Thanks
Trio will fit but may need some low profile/ right angle display cables. It comes with a right angle hmdi cable so will need to think about displayport.
Running a 336mm suprim myself and had to get 3d printed feet so the display cables had space to connect to the gpu.
