- 12 Feb 2006
- Surrey
just want back to 2.1 the other day but quickly remembered why i went to 2.2 and tried re-upgrading tonight. i downloaded what i think is froydvillian 1.5.0 at normal kernel speed with boot animation from this link
http://www.villainrom.co.uk/forum/showthread.php?2358-FroydVillain-1.5.0-quot-Alive-and-Kicking-quot
i then restarted and pressed home button to get in the boot menu. i did a flash or my sd card as i wanted to make sure it was a clean new install as well as reset and cache clear. it couldn't then find the update (i guess flashing sd card deleted the update file so mounted the card and loaded it on. then i chose to run update.zip which seemed to do stuff but was over in less then 4 seconds. now restarting and i just get the HERO loading screen and nothing ever loads
not sure what i can do now as it's not working at all
