Messenger border colour scheme issue
7 Mar 2005
LU7
I sent a GP4 screenshot to a contact of mine over the weekend. After it was finished sending I accidentally dragged the image from its placeholder in the message window onto the rest of the window.
Instantly the image I sent became the background wallpaper of the message window. I was able to fix this quite quickly. However the borders of the message window for that contact only are grey as opposed to the light blues that are default.
Does anyone know how I can fix this? It is only for that sole contact so I reckon there must be a file somewhere controlling this. Any ideas where?
Would a re-install of MSN fix this?
D'oh, and I've gone and modded MSN with the A-patch. I might reinstall it tonight then and not take the paintbrush bit out with A-patch then.
There's a nice patch out for Messenger that lets you remove ads, change how contacts are viewed, use mini images, idle status kicks in when people are idle instead of just showing away etc....
Think its like A-Patch, just called Mess Patch instead.
Run multiple instances of messenger etc.....
And all this time the paint brush was right there.... ;)
A-patch is an equivalent to Mess patch. Does the same things.;)
