Messenging System Software
30 Oct 2002
Hi,
I would like a simple messaging system between computers on the same network, so we can send messages between machines.
The software is for internal use and so must not use internet IM etc.
Any idea on some good software packages.
Thanks
netsend, it displays who is online, and you can send the message to anyone, or everyone.
Only problem is it has to be installed on every PC, bu that can be pushed out as a MSI. simple but works.
Microsoft Exchange Server includes a program that does exactly that, although it may be a bit overkill.
Burnsy
This was only available with Exchange 2000. Its been removed for 2k3 on because they have Live Communications Server which is basically internal MSN messenger.
NetSend will do it but you have to run a cmd window so can be fiddly for users to use. LCS will give you an internal MSN Messenger system
