Evening OcUK! Another question from yours truly as I learn about touching up paintwork on cars.
So far I'm pleased with how it's going, the paint (although a terrible match) has finished well, and I've sanded back the excess lacquer on my trial section, polished it up with some T-cut, and then waxed it. The bit I've done looks absolutely spot on, with just a faint outline of the new lacquer area in the right light, which I'm going to try lightly sanding back again, or maybe just T-cut to blend in.
With the scene set, here is my question. Although whilst sanding back the excess lacquer I also (inevitably) removed some of the surrounding lacquer, once it had been T-cut and waxed, it looks absolutely great. Is the lacquer actually important, or is it just serving the same purpose as a permanent coat of wax, as protection for the paint?
I'm learning on my old second hand Mondeo, since it won't really affect what little resale value it has, and I like new challenges and skills!
Thanks for any input.
