Methodologies for serving a static header
17 Jan 2003
So a common? issue - a website with a common header (logo, menu, contact details etc) to be served across many pages. I t make sense to have a single instance.
Now in ASP.net you can just use a masterpage but if it's only an html (and PHP) site what method would you use: Javascript, PHP or ?
Use PHP:
Code:
include 'header.php';
Or HTML (assuming your server allows SSI)
Code:
<!-- #INCLUDE FILE="header.html" -->
Don't use Javascript as there will be a delay between the page loading and the heading appearing, plus it will mean another request on the server which is rather pointless in this instance.
What Spunkey said, is this for a project at school, or a site your making yourself, it seems better to use some sort of framework, or open source CMS depending on what your doing. If it is just a few simple pages then it might be better to just include a header and a footer.
