Metro Exodus Question
17 Feb 2009
Just bought Metro Exodus Gold Edition for steam on CDKEYS ( £10 bargain )
Activated it in Steam no problem. It's asking whether I want Metro Exodus and or Metro Exodus Enhanced Edition.
Can I install the Metro Exodus Enhanced edition only, or must I install Metro Exodus too ?
Thanks
Believe the enhanced edition has better visual effects than the original and is larger install in size and includes the ray tracing changes. You should be just able to install the enhanced edition alone.
Brilliant thanks.
Enhanced was 77GB..
Original was 75GB
I think if you can't do RTX ray tracing don't install the enhanced edition. I assume a 3060Ti can, so you're fine.
Just got this deal too.
if I choose to download the Enhanced Edition, is the DLC also included and downloaded also?
