Metro LL + 1440p + CF 280x = Disappointment?
15 Aug 2010
N. Ireland
Hi all, as above really.
Received my 2 280x last week and have been playing with Metro LL and have been quite disappointed.
I have everything set to very high except Blur/Advanced Physx/SSAA(set to 2x)/Texture filtering(set to 4x).
My fps stays at 55fps half the times, and the other times it would be on the 30s, or even go as low as the teens.
Did I expect too much from CF 280x?
Will try that now
Just trying out settings here, could someone point out which settings are best set to low?
I have FXAA set to ultra,Ambient Occlusion set to Volumetric Ambient Occlusion and ultra, AA filter set to CFAA(edge-effect), Antisotropic set to 16x.
Is there any of thos I should turn down/off?
Whats the benchmarks score?
Sorry for late reply, just got around to doing this.
Settings I used:
Options: Resolution: 2560 x 1440; DirectX: DirectX 11; Quality: Very High; Texture filtering: AF 16X; Advanced PhysX: Disabled; Tesselation: Very High; Motion Blur: Normal; SSAA: OFF;
Average results:
Average Framerate: 54.00
Max. Framerate: 118.40
Min. Framerate: 19.74
Settings I used:
Average results:
Surely that can't be right:confused:
Options: Resolution: 2560 x 1440; DirectX: DirectX 11; Quality: Very High; Texture filtering: AF 16X; Advanced PhysX: Disabled; Tesselation: Normal; Motion Blur: Normal; SSAA: OFF;
Run 0 (D6 )
Total Frames: 9976, Total Time: 171.2277 sec
Average Framerate: 58.30
Max. Framerate: 124.88 (Frame: 8010)
Min. Framerate: 6.63 (Frame: 1464)
On a 780 classy o/c
